Quick question on Link G3 injector wiring....
Numbchux
Post by Numbchux »
So, I'm wiring in a Link G3 standalone into my buddies '98 LGT (with a 22t shortblock...) and, it has only 2 injector controllers....it says it can run up to 6 injectors of each. now, this sounds like an extremely bad idea, since with a waste spark setup aswell, it sounds like there'll be fuel and spark on the exhaust stroke aswell
The manual specifically talks about running multiple injectors on the same circuit, and separately talks about waste spark setup. so I assume this isn't that odd.....but my limited standalone experience leaves me scratching my head.
also, since I'm at it, assuming this "waste injector" system is right, how should I wire it? the manual suggests 1/3 and 2/4 for a 4-cyl with MPFI. but ignition is 1/2 and 3/4.
