Closed Deck Versus Open Deck
Locked
William D. Robinson
Post by William D. Robinson »
An open deck engine is cheaper to manufacture, as the water jackets
around the cylinders are made by inserting a die that can be slid
straight out the top when the casting has cooled. When the head is off
of an open deck engine, you can see right down into the water jackets
all around the cylinders. This means that the cylinders are standing up
like cans, with little to support them. For highly modified Hondas,
they sell aftermarket blanking plates that fill all the open spaces at
the top of the cylinders serve to brace them from swaying and expanding.
A closed-deck Subary engine is made using the "lost styrofoam" (similar
to lost wax method) technique. When the head is off, you can see that
all the space between the cylinders is sealed off by a solid deck with
holes for the coolant passages, but otherwise solid. This method does
not allow for a casting die that can be retracted from the finished
casting and it requires a bunch of costly machining to achieve a
suitable mating surface for the heads.
The Subaru engines that were designed to be turbocharged have a number
of "bulletproofing features", such as an under piston oil spray system,
extra bracing of the crankshaft bearing areas, etc.etc. My son has a 98
Impreza RS with a Minnam Stage II kit and 5psi boost. He has already
lost a cylinder liner, because his 2.5 open deck engine was not built to
take the strain. That is one reason why I'm not interested in selling
one of my EJ20G engines, he will probably need one soon.
Bill Robinson
-------------------------- eGroups Sponsor -------------------------~-~>
eGroups eLerts
It's Easy. It's Fun. Best of All, it's Free!
http://click.egroups.com/1/9698/1/_/_/_/974665151/
---------------------------------------------------------------------_->
penty
Post by penty »
Thanks William I appreaciate the explanation, so which engine would my 92 UK 2L 4 cam Legacy turbo have ? and would it be Cast die or sand die ?
cheers
John
----- Original Message -----
From: William D. Robinson <mailto:vultureboy@mindspring.com>
To: BC-BFLegacyWorks@egroups.com
Sent: Sunday, November 19, 2000 8:17 PM
Subject: [BC-BFLegacyWorks] Closed Deck Versus Open Deck
Bill Robinson
eGroups eLerts
eGroups Sponsor
<http://click.egroups.com/1/9629/1/_/_/_/974666165/>
<http://adimg.egroups.com/img/9629/1/_/_ ... 468x60.gif>
Gord
Post by Gord »
Thzanks for the lesson Bill, i hope you don't mind i quoted you on "the Ultimate Subau Message Boads, some on asked if Subie turbos were any good.
boyo boyo boyo are they're not good their great
seeya
Gord
Sent: Sunday, November 19, 2000 4:17 PM
Bill Robinson
eGroups Sponsor
<http://click.egroups.com/1/9647/1/_/_/_/974674615/>
<http://adimg.egroups.com/img/9647/1/_/_ ... 8x602F.gif>
Dave aka DLC/dackampf
Post by Dave aka DLC/dackampf »
I'm going to make a minor correction but in reading Mike Shields'
explaination, Lost-Foam is very similar to die-cast.
All Closed-deck Subarus are Sand-cast.
Again, i'm going from what he's said, and that's a pretty good
source! I just hope i interpreted it correctly.
--- In BC-BFLegacyWorks@egroups.com, "William D. Robinson"
off
jackets
standing up
at
expanding.
(similar
that
with
does
number
system,
a 98
already
built to
selling
> Bill Robinson
eGroups eLerts
http://click.egroups.com/1/9698/1/_/_/_/974701148/
Look on the top of the block for a ###-type hash pattern. If you see
this anywhere, it's a closed deck.
sand die ?
> cheers
> John
jackets
is off
jackets
standing up
Hondas,
spaces at
expanding.
(similar
that
with
does
finished
number
system,
has a 98
already
built to
selling
> Bill Robinson
eLerts
http://click.egroups.com/1/9699/1/_/_/_/974701195/
Nevermind!
I was wrong, it is Lost-Foam!
Thanks Will!
--- In BC-BFLegacyWorks@egroups.com, "Dave aka DLC/dackampf"
jackets
is
> off
> jackets
> standing up
Hondas,
spaces
> at
> expanding.
> (similar
> that
> with
> does
finished
> number
> system,
has
> a 98
> already
> built to
> selling
> > Bill Robinson
eGroups eLerts
http://click.egroups.com/1/9698/1/_/_/_/974701466/
Locked
