yes and i do know the 60 amp was a big no no i just wanted to try to get it home
thanks for your help
That is very true. You can overload the wire before it takes out a slow burn fuse. This will result in melted wire casing and exposed wires...94legacy2.2 wrote:Also stop putting in bigger fuses, you'll have a fire soon.
Punctuation, like spelling and grammer, is a tool to help people communicate effectively. It's a way to get what you want. You want people to give you information, in this case about your car. The better you communicate your idea, the more likely you will get what you want.92LegacySpOrT wrote:... I like to think of forms as I/M's so I use them like one besides your brain should fill in the puctuation any ways lol :-D
