i need a head gasket now!!!!!!
will a dual overhead cam gasket set work for my single overhead motor i just am going to use the head gaslets and what will fit anyone please i need to find them quickly so i can order them
1990 legacy ej20t
Re: i need a head gasket now!!!!!!
I think the bore size might be off a tad.anthonyej20 wrote:will a dual overhead cam gasket set work for my single overhead motor i just am going to use the head gaslets and what will fit anyone please i need to find them quickly so i can order them
also the coolant passages arent the same, you'll have problems down the line.
im slow---Location:Colorado
Got squirt? http://www.msextra.com/index.php
- quasi-mod-o
Do you think you can be any more vague? There's about half a dozen SOHC head gaskets and about half a dozen DOHC head gaskets. What exact parts (with years and original vehicle) are you using?anthonyej20 wrote:will a dual overhead cam gasket set work for my single overhead motor i just am going to use the head gaslets and what will fit anyone please i need to find them quickly so i can order them
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
I think he's asking if something like a HG for an '02 WRX 2.0 would work for his EJ20. I could be wrong about his idea.
Jason
www.subarugenuineparts.com ??? Helpful?
Well no matter what your car is you buy the gaskets for that motor. If you swapped in a ej20 then buy the gaskets for that motor. If you need just the head gaskets then tell them you need just head gaskets not a head set or master set.anthonyej20 wrote:what dropdfocus said is correct thats what i need to know my car is a 1990 with a 94 ej20 turbo
I think the problem he is having is the motor was swapped over before he purchased the car. So he's trying to identify if the motor truely is a JDM EJ20 or not.
Jason
The older ej20's used the thick HG. And the newer ones use the thin metal shim HG. I don't know if you can find the thick ej20 HG, can you?
I used the metal shim HG on my JDM EJ20 and I could barely get the intake manifold bolts in. I think this cause the heads to pull away from the block and may have caused an oil leak. I'm not sure, but somehow that JDM motor used about 3 quarts of oil in 3 weeks and eventually led to my second engine's demise.
Yellow '01 Kaw. ZX-7R (SOLD) :(
Gold '88 Starion ESI-R (Drift Project)
Brgndy '92 Legacy SS, Agency Power Style Headers and Up-pipe (ebay, don't stay together), Underdrive Pully, 5MT conv, mod'd WRX cold air intake and short shifter, 12.5 lb fly
Oh yeah. So always use the right HG. And always check your oil after swaps or rebuilds. I have to learn these things the hard way...
