Koyo aluminum radiators kick ass!
SuperRallyRoo
http://www.jazzproparts.com/product_p/r1819.htm
So basically Jake from PIA said these rads kick ass so I bought one when he was sitting right next to me. Showed up at my door promtly. And got its gorgious holds a ton extra water OEM fit is perfect. Makes the TW look like I have a fatty FMIC. And now my shit has a ALL aluminum radiator! woo hoo! Pics when I have time will come. The best part is it can be yours at your door for 216.00 shipped!!!
It is a true turbo style with no fill hole. Fit my 92 touring wagon perfect!
Legacyless
98 Jetta TDI
98 Jetta TDI
I've been thinking about one of these for my Legacy, did you have any problems with the stock fan clearing the Alt/ps belt?
The one I have on my Impreza was a PITA to get in & the fan had to be notched a smidge to clear to Alt belt, but it works very well...
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
Does anyone know if the Impreza one fits the N/A Legacy? The turbo Legacy is too tall and I'd rather not modify the car to fit it.
denver_whitest185
Re: benefits
larger water capacity, which increases thermal efficiency of your cooling system. it makes it easier for your engine to run at normal operating temps. however, you don't really need an upgraded radiator unless your making quite a bit more power over stock or racing extensively.kleinkid wrote:What are the benefits of this larger radiator over the stock radiator?
1994 maroon Subaru Legacy SS sedan
1990 white Toyota Celica Alltrac - well modded :D
Bring the track to you
http://www.youtube.com/watch?v=mXfUbFR-x7g
The alloy is also nicer than stock brass as there's no electrolytic reaction.
SuperRallyRoo
denver_whitest185
SuperRallyRoo
You know, the part that is supposed to go in between the top of the radiator and the support beam. It would essentially be underneath the mounting brackets that the hood support clips into.
In your picture there is a gap. A part exists to fill that gap so air cannot escape over the radiator and through the engine bay.
I'd like a full frontal shot when you have one...
Pretty darn cool, ...note to self...I want this!
Does anyone know if Koyo has an equivilant part that'll work for those running a turbo motor in an n/a chassis (where a turbo rad won't fit without welding in tabs)?
denver_whitest185
you can make your own pretty easily. thats what i was talking about earlier in the thread.vrg3 wrote:ciper - That part is only on pre-facelift models, I think.
http://www.wrxfanatics.com/index.php?showtopic=48942
Isnt that always the case! Everything good is always on the prefacelift models, especially the Japan built ones (like little white dots on the heater vent controls)vrg3 wrote:ciper - That part is only on pre-facelift models, I think.
I was thinking the same thing and thats why I started this threadbeatersubi wrote:Does anyone know if Koyo has an equivilant part that'll work for those running a turbo motor in an n/a chassis (where a turbo rad won't fit without welding in tabs)?
http://bbs.legacycentral.org/viewtopic.php?t=33935
dropdfocus
Koyo radiator for SS back order at mfg.
Koyo radiators for the Legacy SS are on back order at Koyo. About 3 weeks. Seems to be a little rush on them right now.
dropdfocus
With those prices I can see why there is a back-order.
My Impreza KOYO does a really good job of keeping things cool - too good in fact with 70mph winter cruise temps dropping down to 128-132*.
I'm ready to go ghetto & put a piece of carboard over a section of it.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
96 Impreza OBS
99 Impreza OBS-T
