Differences between NA / Turbo radiator (beside filler cap)?
ciper
Post by ciper »
My memory fails me but I swear I remember that one of the radiators was taller and because of this the "frame" below it was different. Who can clarify with measurements and such?
thehookeup
Post by thehookeup »
im pretty sure they are nearly the same, other than the cap in a different spot. they have the tranny oil cooler
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
I don't recall measuring the difference in lower mounting heights on my parts turbo and the N/A wagon (and the parts car is long gone), but the turbo radiator is 17.25" and the N/A 16" tall. The hood on my N/A won't come close to closing with the turbo radiator.
The tranny cooler is only on the autos.
ciper
Post by ciper »
That is good to know.
What is needed to modify an NA body to fit a turbo radiator? I assume it is only the lower mount but isnt this part welded/painted to the car? I'm very interested in the koyo radiator someone recently reviewed.
I am sick and tired of the crap OE radiator end tanks cracking. I'd bet that more Legacys die of cracked radiators than any other cause (including accidents)
Yeah, my replacement N/A is only 4 years old and crumbling so I don't want to trust it with the turbo, but the turbo radiator I have won't fit, so that's one reason the car's been sitting for a couple years.
There's a double-skin lower mount welded in place, which is why I'm reluctant to modify it. Any time you cut metal up here, you're looking for corrosion issues. Looks like there's only about a half inch to gain anyway by removing the upper skin.
That's why I was wondering if the Impreza one fits, possibly being shorter than the turbo Legacy.
ciper
Post by ciper »
I bet we could contact the manufacturer of it (or a similar unit) and get the specifications. I have only found one all metal radiator for the NA Legacy and it was a little too soft for my liking. I almost broke the filler neck clean off the first time I replaced the cap.
Are the NA and turbo chassis different in every model year, or just in 1990 or just in 1990 and 1991?
bmxpunk
Post by bmxpunk »
My impression while looking for myself a KOYO was the turbo legs and the GC impreza were the same. I am really interested now, since that is the next item on the shopping list
2011 Mini Countryman S All4
1970 Honda Ct90
GLCraigGT
Post by GLCraigGT »
There are three kinds of people in the world, those who can count and those who can't.
2009 STI, It's staying stock, well at least the first 100K
84 GL Wagon With Factory Brushgaurd, The Lack of Power Wagon RallyX machine.
SemperGuard
Post by SemperGuard »
vrg3 wrote:Are the NA and turbo chassis different in every model year, or just in 1990 or just in 1990 and 1991?
All of the NA Legacys have the same size radiators, and same space from bottom to top in the chassis, and all the turbos have larger radiators, and larger space.
livestrong14
Post by livestrong14 »
So people who have swapped to a Turbo engine in a non-turbo legacy can't use Turbo radiators? Can the N/A radiators handle that task?
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
Post by 555BCTurbo »
livestrong14 wrote:So people who have swapped to a Turbo engine in a non-turbo legacy can't use Turbo radiators? Can the N/A radiators handle that task?
No, they can...Jake Talbot (Jake15) knows how to modify the radiator to make it fit in a NA chassis (as his began life NA)...NA Radiators can handle the task to an extent, but from what I have seen, they tend to run a wee bit hotter.
livestrong14
How do you go about modifying it? What has to be done?
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
ciper
Post by ciper »
I dont think the radiator was modified. I cant see how you can make it an inch shorter
Thanks, SemperGuard. I was wondering if it was a 1990 thing because the only evidence I heard of before was from 1990 models, which just happens to be the one year that there was no turbo model.
SemperGuard
You have to cut and weld the lower radiator support. As was said, the NA radiator is fine to an extent. Track it and it overheats.
So do the N/A Imprezas have the same size as the turbo Legacy's? Would seem to make sense, I guess, as the shell was used for the Impreza turbo/WRX.
SemperGuard
No, only 90-99 NA legacys have the small radiator, and small size. But it's not all bad. I have an idea that I want to confirm 100% before I post anything. Impreza, Forester, 00+ Leg/BAJA all have larger rad and size.
nortonjefferson
Re: Differences between NA / Turbo radiator (beside filler c
Post by nortonjefferson »
Bump from the dead, does anyone have photos of how they modified their NA crossmember to fit a turbo radiator? I have a means of fabricating and cutting but id like to see how others have done it (if they have) before I buy a turbo rad and commit to cutting stuff up. Thanks!
White 1993 L Wagon AWD 5MT-FXT lift, 27” MTs 380xxx miles
White 1991 L sedan AWD 5MT-(Robtune 550 DOHC Ej22t swap coming together) 187xxx miles
Black 2005 LGT 5MT-Ej20x swapped daily, VF40/elh
I know there is a small handful of people that have modified the lower radiator support so hopefully they took pictures and can chime in. However, as I understand it, the entire lower core support is just lower. The turbo support's bends that attach to the chassis are longer so the horizontal part of the core support sits lower to accommodate the taller radiator.
impostor
Post by impostor »
Here's my story for informational purposes. I have a 95 Impreza with an EJ22t swap done by me in 2003. I installed the correct legacy turbo radiator, and it fit like crap. It was too big so I angled it back slightly at the bottom which also made the fans come within about a quater inch of the front engine accessories. A year ago the LH tank cracked. I went through our inventory or radiators at the shop and noticed how the 04-08 FXT aluminum Koyo radiator had everything in the right places. Almost fits like a glove. I did have to buy the FXT style upper support brackets. I used an FXT cooling fan shroud and blades, and legacy fan motors. I have an engine bay shot in my "AWIC folks..." thread.
Sooo, based on what you guys are saying, it sounds to me like the n/a legacy and n/a impreza are closer in dimensions.
rallyak
Post by rallyak »
If you need to buy a new radiator anyway I would look in to a gt radiator with a thicker core, it fits the n/a opening and has more cooling. I have a new oem one going in my car when I do the motor swap.
Charles
nortonjefferson
Thankyou everyone for your input/suggestions! Looks like I'll be opting for the gt radiator, Josh is spectra the brand of radiator you're running? Or just oem? If spectra have you had any issues in the long term with it? i think I'll just spring for a 96-97 gt spectra model! Thanks again everyone, I know this has been covered a lot lol.
EDIT: I ordered up the spectra legacy gt radiator. $102 with tax and free shipping from amazon. For anyone referencing this for info the SPECTRA part number is "CU2082"
I ended up getting a Subaru OEM GT radiator.
Let us know how the Spectra radiator is and if you don't mind sharing some pictures that would be great.
