94 Legacy trouble after timing belt replacement
andrewz
Post by andrewz »
I just bought a '94 Legacy AWD in non-running condition. I found the toothed idler for the timing belt had failed. I changed all of the idlers and the belt. The belt had timing marks on it and the marks matched the info I found at endwrench.com. 44 teeth from passenger side cam mark to crank mark, 40.5 teeth from crank mark to driver side cam mark. I put it all back together and it still won't start. I have 170 psi on 1, 150 psi on 2, 155 on 3, and #4 I had up to 150, but it took about 6 compressions. Not sure that the connector was on tight enough on that #4 cylinder, as I can't get a wrench on to tighten it. I have spark. I smell gas after cranking. Cylinder 1 at TDC has the crank pulley timing mark close to 0.
I can't use my OBD-II connector on it. I connected the black pair of test plugs and get a steady, constant blink on the check engine light. I connected the green pair and the fans ran, relays clicked, etc in a continuous cycle.
Oh, by the way, it has something like 228,000 on it.
What am I missing? :?
Are you sure you used the correct timing marks on the cam pulleys? There are two sets and are easily confused.
andrewz
Post by andrewz »
I saw only one mark on the perimeter of the pulley. Is that the correct one? Would the compression be 150+ if the timing was off?
andrewz
Post by andrewz »
I verified that I used the correct timing mark on the cams, not the piston position mark. Any other ideas, anyone? Does the steady blink in read mode indicate no problems detected by the ECU? The spark plugs look bad, but it seems strange that it was running until the timing idler failed, and now won't start at all.
scuzzy
Post by scuzzy »
if I remember correctly there's a couple places where you can point the marks on the cams to line them up, one is right and one is wrong, same for the crank; I think there's a notch and a dot on the sprocket but I can't recall.
it's been about two years since I've looked at mine.
make sure the crank sensor and cam sensors aren't mangled, if the pulley failed there's no telling what could have gone with it.
edit: also don't read too much into those compression numbers until you get the engine warm, if it's been setting for an extended duration then the compression numbers will be out of wack due to oil drainage and such.
#82 M4 TRSCCA Rallycross
andrewz
Post by andrewz »
I found the problem! I found a reference on another site about two timing marks on the crank also, not just the cams. Tore it apart, fixed the alignment, she starts right up. Thanks, scuzzy for your post. The correct mark on the crank is behind the belt on the sprocket for the crank position sensor. The endwrench.com article does have it correct. :D
ciper
Post by ciper »
I litereally exploded my intake by using the wrong crank mark. The MAF tube was the weak point and it cracked open. Nothing a little super glue and epoxy couldnt fix :)
adema2626
Post by adema2626 »
Thank you guys for helping me with my problem to! haha and thank you Matt Monson for directing me in the direction of this post!
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
Steeper
Post by Steeper »
I like that these 2.2 sohc are non interference!
93 impreza wagon
95 v2 STI RA drivetrain
FMIC
002.5 RS bumper and 95 wrx hood
SS 3in TB
