Trying to shift a stiffy...
Arctic Assassian
Post by Arctic Assassian »
Not a loosey....
My shifter sucks. Besides being too long, it's floppy, notchy, and overall just too lose.
I've priced out groupN tranny, engine and pitch stopper... that with cobb shifter bushings = about $260
I've read about a spring you can replace to stiffen things up a bit, and I'm gonna use a double adj. SS to fix the height problem.
I was wondering if there is anything else I can do to tighten things up a bit. also some input on the bushings, and exactly what effects I should plan to see.
BTW I searched for awhile at work, but couldnt seem to come across any of the threads I remember seeing before.
-Adam
Kickin' it old-school.
Are you planning on keeping the older shifter design, or upgrading to the newer one?
Arctic Assassian
whats the difference? I was under the impression my car shared the design for the older impreza.
There's slight differences in the joint that attaches the linkage to the transmission shift rod. That's the main thing.
Arctic Assassian
Could you maybe point me to some info?
Subyluvr I believe took some pictures or replaced the stock shifter bushings.
I've got pictures of the newer style here
http://bbs.legacycentral.org/viewtopic. ... ft+linkage
Arctic Assassian
hmmm. I think I'll be able to figure it out.
tris91ricer
Title Whore
Post by tris91ricer »
I've tried shifting a stiffy. It doesn't matter what you do with it, the whole class is still gonna know if the teacher calls on you. Let me know if 8th grade went any better for you. . .
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
Arctic Assassian
Glad you caught on...
