2.5 ecu questions
2.5 ecu questions
ok guys first off i have a 1997 legacy wagon gt with a ej25 and plan to put my turbo, up-pipe, downpipe, etc. on the car and was wondering if the stock na ecu would reconize the turbo if so is there anyway i can fix this without switching to a piggyback ecu or chopping up the wiring harness and addind all of the necessary turbo sensors?
ej22t hybrid, 3.5" downpipe, Gl turbo intake/desnorkel 9psi DEAD
Just a heads up - a 2.2t intake manifold will not bolt up to DOHC heads, you'll need an Old style DOHC intake manifold (as '02+ WRXs have a different bolt pattern).
The phase 1 2.2 ports are much smaller than DOHC ports & the manifold will not line up with the heads.
Interesting enough phase II 2.2s have WAY bigger ports than PI 2.2e&t's & '02+WRX intake gaskets will fit (but have to be switched around - left on right & right on left - (I have WRX Hondata Gaskets on my PII 2.2e))
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
- quasi-mod-o
The engines don't care what care they came out of. No 2.5l engine will accept an early 2.2l manifold. See the previous post to know what your options are.the_watts10 wrote:well its a 2.5 legacy outback will that work?
Also be aware that you can run a lot more boost against an NA Ej22 than you can an Ej25. Ej25's are delicate engines under boost. crack. snap. kapow...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
Yeah I did not even mention that, but 100% of the people I know with turbo 2.5s blew the engine.
Actually I only know 1 guy that had a AVO turbo-kit & the engine blew after something like 8k miles, the car had just 16k miles on it when cyl #3 lost compression (1 of 1 = 100%).
You may want to put 2.5 heads / intake on a 2.2 block to get something more boost friendly.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
96 Impreza OBS
99 Impreza OBS-T
- quasi-mod-o
Suby Hai!
Suby Hai!
Again if you are using DOHC heads you have to use a DOHC intake manifold.
If you compare intake gaskets of the 2.2 intake vs the 2.5 intake you'll see the 2.5 port size is like 1.5 times the size of the PI 2.2 port.
I'd say that should work better.
Note: the CR with the DOHC heads may be LOW depending on the Heads / headgasket used.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
96 Impreza OBS
99 Impreza OBS-T
