Hi all,
I have a 2.2 L NA engine.
I'm tearing apart my engine and putting it back together with new gaskets to try to hunt down a leak. While putting it back together and getting ready to put on the timing belt, I noticed the driver's side camshaft and sprocket is a lot harder to turn than the passenger's side; although they both turn. Is this normal or should I go back and check my work?
Driver Side Camshaft
Yeah, depending on where the cam is, it will be more difficult to turn. When aligning the timing belt, the passenger side is at a spot where it turns pretty freely, and the driver's side is more difficult. It's probably between lobes.
