My name is Devan Daugherty. I am a 17 year old junior at Kuna High School in Kuna, Idaho. I am the proud owner of a 1991 Subaru Legacy Sport Sedan. I came to love Subaru's back in 2004 at the age of 14. My father, Dale Daugherty gave me this car to be a safe, fun, and reliable car for my up coming high school years. Little did we know that this car would end up being not only my pride and joy, but also the flagship for his new business.
My dad purchased this car back in 2003 at a local auto auction for $300. At the time it arrived at our shop it was covered in mold, and had a blown automatic transmission. We were very new to Subaru's at this point and knew nothing of this car's many capabilities. I had been a fan of Subaru's dominance in the WRC for years before we started modding my Legacy. My dad I were lucky enough to attend a Rallycross at the Washington County Fairgrounds setup by Oregon Rally Group in June 2005. That is where we had the privilege of meeting Kelly Gibner formerly of RalliTEK Subaru Performance. Kelly told me about the forum legacycentral.org and said that was the place to look and see that the rest of the world is doing with these forgotten rally rebels.
Several months and a few dollars later we came across a JDM EJ20G taken out of a JDM Legacy RS touring wagon. A few months after that we came across a JDM 4:44 5-speed transmission taken from a Legacy GT Spec-B. In the summer of 2006 we started the tear down of the legacy in its stock form. First to go was the worn out 2.2T SOHC engine. That has been a pretty controversial decision amongst the Legacy Turbo community, but with our lack of time, we decided to do a straight up swap. now equipped with a DOHC turbocharged and intercooled motor, it was ready for its maiden voyage amongst the rest of the modded Subaru's seen throughout the northwest.
Since the spring of 2006 I have been competing in Autocross and Drag racing events in my hometown of Kuna, Idaho, as well as raced at PIR in Portland. This car has made quite an impression amongst my fellow high school drag team here in Idaho. The car has undergone many suspension, drivetrain, braking, and cosmetic upgrades over the last year or two. I still have many dreams and aspirations for this project.
This was all built by my dad and I, the father and son team at Northwest Subaru Service in Portland, Oregon. It has been a fun ride that will probably never end. I am glad that I got the chance to share my car's journey with you all. We have come this far with the car. I believe it is tome to share my project with the rest of the world. Thanks for reading.
Mod List
Engine/Performance
2.2L Closed Deck Short Block with factory piston oil squirters
JDM Legacy RS EJ20G Heads
JDM IHI VF8 Turbo
Legacy RS Air/Water Intercooler
Custom Frontmounted Heat-Exchanger for AWIC
Bosch Electric Water pump for AWIC
GPMoto 3" Stainless Downpipe
Magnaflow 3" Cat-Back
Manual FCD
RalliTEK Perfect Power SMT6
TurboXS MBC
TurboXS BOV
Walbro 255cl Fuel Pump
HKS Super Mega Flow Intake
JECS MAF
STi Up-Pipe
Diamond Coil-Pack
Transmission/Drivetrain Performance
JDM Legacy GT Spec-B 4.44 tranny swap
4:44 Clutch Type Limited Slip Rear Differential
'04 WRX Flywheel
Excedy Stage 1 WRX clutch
'98 Forester Hydro Clutch Master Cylinder
'98 Forester Hydro Clutch and Pedal Assembly
'03 WRX Shifter Linkage
B&M WRX Short Throw Shifter
PERRIN Shifter Bushings
Group N Motor Mounts
Group N Tranny Mount
Group N Pitch Damper
RalliTEK Exhaust Hangers
Whiteline Steering Rack Bushings
Exterior
Body Color Door Handles, Mirrors, and Hoodscoop
Custom Pillarless Grill
EVO 8 Grill Mesh
Custom Amberless Cleared Tail Lights
JDM Glass Headlights with City Lights
EDM Sidemarkers
Sylvania Silverstar Bulbs
Hella Supertones
Pinstripes removed
Blacked Out Subaru and Legacy Badge
Blacked Out Trim
Interior
Satin Black Interior Panels
Custom Dark Grey Suede Headliner
Custom Graphite Door Cards
'93 SS Factory Black Carpet
JDM Legacy GT Spec-B Steering Wheel
Autometer Ultra-Lite Boost/Oil Pressure Gauges
'01 RS Black Front and Rear seats
Greddy Counterweight Shiftknob
Black/Red Stitched Suede Shift Boot
Type RA Style Red Needle Gauges
Sony XPLOD Head Unit
Pioneer Speakers
Suspension/Wheels/Tires
KYB AGX Gas Adjust Shocks
Whiteline Flat Out Springs
Whiteline 22MM Front Swaybar
Whiteline Heavy Duty Front Endlinks
Whiteline 20/24MM Adj. Rear Swaybar
Whiteline Heavy Duty Adj. Rear Droplinks
Whiteline Front Strut Tower Bar
Whiteline Rear Subframe Lock Bolts
CUSCO Rear Strut Tower Bar
SimplySubie Rear Strut Support Bar
SimplySubie Fender Braces
Megan Racing Underbody H-Brace
'05 WRX Wheels Painted Obsidian Black Pearl
Work Racing Red Lugnuts
205/55/16 Hankook Ventus RS-2 Rubber
Brakes
Front:
'04 WRX Calipers
Agency Power Stainless Brake Lines
Brembo Slotted Vented Rotors
Metal Master Ceramic Pads
Rear:
Vented Rear Rotors
Ceramic Pads
ATE Superblue Brake Fluid
Waiting on:
Whiteline Anti-Lift Kit
Whiteline RCA Kit
Ground Control Adj. Coilover Springs
The Car:
Vid of new engine start up!
Went to PRE while over Spring Break to see how the car was coming along. Tuned at a conservative 16psi. Quite happy with the numbers! Enough power for me at the moment!
Video!
http://www.youtube.com/watch?v=LWzdDpFjh14
226 WHP 268 WTQ!
[/CENTER]
