Cooling plate
Cooling plate
Not sure if it fits here. It's a cooling question though. So I have a bone stock 91 Legacy L with an EJ22 NA. Looking for a cooling plate. Any suggestions. Will one for an Impreza fit?
Not exactly something more like this... I'm not fluent for inserting images, here's the link.
http://www.invoauto.co.uk/images/Produc ... y1-lrg.jpg
It's the stainless steel piece on top of the radiator.[/url]
At the least, you'll need to drill new holes since the mounting tabs for the Legacy radiators are straight and not curved like the Imprezas. Some hammer work would probably also be in order if the shapes of the girll/radiator support beam are slightly different.
greg donovan
blackbartCobalt wrote:Ok, I'll pull an OJ. Just saying hypothetically IF I can't find a junked first gen legacy with the radiator cooling plate, where could I order one or get one. Sans the local Subaru dealer. Google isn't helping much.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
I made one for my 91. If I was good with the pictures I would include one. It wasn't very hard. I just started by making a template out of cardboard. I did do some work on the phone to find a place to brake the aluminum down to size and then bend it when I finished all the other short cuts.
I have never seen a cooling plate on any early Legacy so finding one in a junkyard is about nil.
Jeff
Jeff
subaru_styles
