ok iv read around that its no possible to make EJ22T injectors work with a EJ20G fuel rail because EJ22T injectors are side feed and EJ20gs are something else i forgot. But with my EJ20G heads i swear they are side feed because they are set up exactly how the EJ22T fuel rails are. The only difference is that the EJ22T fuel rail is shorter then the EJ20G.
I have EJ20G heads from a early legacy motor 90-94??
Is there anyway to get EJ22T injectors to work on EJ20G fuel lines/fuel rail. Because the fuel lines are different the EJ22T fuel lines wont fit around where the intake manifold arms.
Any help would be greatly appreciated. Thanks
EJ22T injectors in EJ20G rails....
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
wow... wait iv been hearing differently... shit yes... haha turns out 2 of my 20g ones are stuck open! that solves my problem! lets get this son of a bitch running! thanks nick
