want a hood for 1990 legacy ls
Post by SILINC3R »
is there a hood woth a scoop that will fit my car.
Get a turbo legacy hood for a 1991 legacy turbo. Or cut a hole in your hood.
Post by SILINC3R »
would it fit nicely or would i have to fabricate
The 91 hood, or cutting a hole in your 90 hood?
The 91 hood will fit fine, bolt on.
Cutting...obviously you'll need to do some custom work.
Dynamic Entry
Post by Dynamic Entry »
any hood from any 90 or 91 Legacy will bolt on directly
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
Any 90-91 MY Legacy hood is interchangable.
Post by SILINC3R »
yea i meant the turbo hood. was that interchangeable. how much and where could i get one
jp233
Post by jp233 »
Hey since i see you're in Georgia, there are a few good 90-94 Subies at Pull-A-Part (Atlanta North). Well, the ones I haven't raided yet.
I know the Atlanta South location has a few cars too, but I haven't been there.
There are two good '91 hoods there at the ATL North spot, albeit they aren't turbo cars. But, since they are only $28.71 at the pullapart... you could buy one and then hack it up without worry if it gets screwed up.
Yes, all 90-91 hoods (turbo or N/A) are interchangeable.
I am assuming a 91 hood won't fit right on a 92-94, due to the headlight change?
12 Outback 3.6R Limited
94 Leg LS wag AWD, sold
93 Leg L wag FWD, sold
06 LGT 5EAT, project
Post by SILINC3R »
hey could you get me directions
jp233
Post by jp233 »
www.pullapart.com
they are also supposedly opening another yard in Lithonia GA
Post by SILINC3R »
i think iwent to this one and they had a wagon. i will nee to check it out again
