side mirrors on my '93 SS worked fine yesterday and today don't adjust.
there are no blown fuses and i partially pulled the door panel to see that the harness connector is intact.
after searching all 27 pages of past posts, i'm asking if anyone has had this problem before.
thanks
troubleshooting side mirrors
fixed
the DS mirror had gotten locked at the extreme position. after repositioning the mirror manually and flushing out some built up dirt, the motor worked again. it most have a burn-out fault circuit to protect the motor.
