collant temp sensor , knock sensor, o2 sensor precaution?
do i have some special care before going into the process of changing thoise sensor i just receive them and just wanna double check if there any precaution i should take before doing this
No not really...
You'll need to drain the coolant to replace the coolant temp sensor, or do it quick enough so you only have a little bit of coolant leak out.
