Also, there is a large pack of wires running along the firewall (assuming these are from computer..), and this if the main thing preventing me from from lowering my intercooler, allowing it to clear the hood. How do i go about relocating them ?
Next, the throttle cable/cruise cable, where they mount to the arm on the engine, seem to be VERY close to the BOV flange, which is currently not Installed, when installed i fear it will hit. Again, what do i have to move to push the IC back
One final thing, theres an oil line coming off my turbo directly below there i need to run a hose. I loosened the bolt (bolt with hole, banjo bolt), but it doesnt appear that i can rotate the fitting (90 degree metal elbow). How do i rotate this ?
I know these things are a 100% custom job, but I have all day off tomorrow and hope to finish it. Today i fabbed my Y pipe, relocated coolant res, bought all my parts, and cut my clutch res 2" (too little? too much ?)
Thanks for the help
- Josh
