Sean-welcome to the group! Here are some basic suggestions to improve your
mileage; 1st-try changing you O2 sensor; they`re only good for about 50k
miles-check your plugs & wires-plugs should be changed every 30k miles &
wires usually every 100k miles or if you have any carbon-tracked plugs-try
8-8.5 mm Magnecor or NGK wires. Do you have the original coil pack? If so,
upgrade to the late RS pack from a 2.5 Impreza (almost a 50% increase in
potential spark). Try a K&N Filtercharger as a replacement for the paper
element-you`ll notice a difference. If you`re bucks-up, get an MSD Dis-2
unit as an addition to your ignition-it`s a capacitive-discharge unit that
will increase spark & mileage (I`m saving for one now). Lastly, make sure
(if you have them) your cats are`nt restricted as that will definitely
affect mileage. Don`t know about very cold weather affecting your mpg, but I
would`nt be surprised. Good luck from ROD (somewhere in Arizona)
----- Original Message -----
lukan.sean@optimaepc.com>
To: <
BC-BFLegacyWorks@egroups.com>
Sent: Tuesday, January 02, 2001 12:47 PM
Subject: [BC-BFLegacyWorks] Hello from new member
> Just thought I would take a second to introduce myself before I ask
> any questions of the group. I am a 30yr old male living in Calgary
> Alberta. I own a '91 Legacy turbo AWD with automatic transmission
> Well, sad face only for the tranny part. The car has 350000km on it.
> Since winter has come on I have been experiencing horrible gas
> mileage in the 300km/tank range. Sure I'm a heavy foot but normally
> mileage was at least 400km/tank city and 500-550 highway. Anyone have
> any input on this or things to check. I was thinking O2 sensor, PCV
> valve or something in that area. I'm currently changing the struts
> and went with KYB GR2's. I believe the struts that I removed were
> originals but I'm not sure. I'll have to look at the service records
> to confirm this. When I reassembled the struts I discovered that my
> springs also need to be changed (I was able to compress the springs
> and assemble the struts without the use of a strut compressor!).
> Anyways my biggest concern at the moment is the mileage. Once I get
> that sorted out I can worry about adding power. Thanks in advance for
> any help.
> Sean
> To unsubscribe from this group, send an email to:
