Prodrive Pr0n
- quasi-mod-o
Prodrive Pr0n
http://www.clubgti.com/forum/showthread.php?t=176467
Enjoy. I'll be reviewing that thread in detail repeatedly in the next week or so.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
Absolutely nuts. Thanks for linking it Matt.
It's hard to believe that there is that much money in racing. It's even harder to fathom that F1 is even crazier.
They are slacking a bit though.....
To finish up this mega day, I watched a WRC Impreza driven into the service area, and saw the mechanics take the gearbox out, and replace it in a stunning 6 mins and 2 secs.
That's from being on the ground, to on jacks, tested up & down the gears in the air and back down again. The fastest on the weekend was under 6 mins.
Just did...oh, those cars are off the hook on the 2nd section...
That e30 M3? Good god!
Love the old speedlines!
Of Course!!legacy92ej22t wrote:anyone notice the Legacy RS?
Just wasn't going to spoil the suprise for everyone else.
PhyrraM wrote:Absolutely nuts. Thanks for linking it Matt.
If you were really on your game, you would have noticed that they are still using the same closed deck 2.0L block they were 15 years ago. It is amazing that that particular block is still the basis of the WRC engines of today. Even if they use two timing belts.
- quasi-mod-o
Exactly. If it ain't broke, why fix it? This applies to both the block and the oil seperator plate.93forestpearl wrote:PhyrraM wrote:Absolutely nuts. Thanks for linking it Matt.
Suby Hai!
Suby Hai!
Is that the plate that everyone says needs to be replaced with a metal one? Mine is plastic(the big one on the right)and someone mentioned replacing some separator plate with a metal one because it cracks but I wasn't sure what they meant.
Interesting. Do you replace just the big plate or the smaller one in that picture as well? I can't imagine the dealership selling anything for as low as $20. What year did you buy this part in? lol
What's the purpose of this plate anyways? Do you remove it to get access to something inside the block?
Well, it was five years ago, but still, they are cheap. Behind that plate(the large one) is access to the #3 piston pin. The small cover, through which you get at the #4 piston pin, is already aluminum, and sealed with an o-ring. The oil separator plate is only sealed with RTV.
Edit: The new one is stamped steel, so it shouldn't be expensive.
- quasi-mod-o
Did you guys notice that the manifold and heads still use the inline bolt pattern like the early ones as well?
Suby Hai!
Suby Hai!
As in the intake manifold to head bolts are all in a line? I guess I didn't notice that. My experience with the newer stuff is exponentially less that the old.Matt Monson wrote:Did you guys notice that the manifold and heads still use the inline bolt pattern like the early ones as well?
What I did notice is that there are still only four bolting points for the tranny bellhousing, instead of eight. That may have to do with still using the old casting, and also less time to swap the motor if neccessary.
Also, did you see how many knock sensors they have on the block, and not in the factory location? I see three in the picture (I think).
oh yeah I just noticed the 4-bot bellhousing. Also from what I've heard they have their own castings for the block and heads, with different coolant passages and bearings.
This is hot:
I want to know more about the anti-lag system they use.
I wonder what you need to do to the oiling system of the turbo to angle it like that. I've heard a little electric oil pump. I'd love to make a rotated setup like that, although it looks like you'll need a wrc crossmember too. I also like how the turbo has it's own exhaust outlet for the wastegate.
ATP does this:
but we haven't gotten good numbers out of the setup.
This is hot:
ATP does this:
jamal wrote:oh yeah I just noticed the 4-bot bellhousing. Also from what I've heard they have their own castings for the block and heads, with different coolant passages and bearings.
This is hot:
It is definitely possible that they have different internal sand castings for the molds. Externally they seem to be identical. Dave at Rallispec says they basic block is the same, but honestly, who the hell knows.
As far as the turbo goes, i would not put it past them to have IHI build a center section that can take being mounted at a 60° angle, or more as it is hard to tell. If they designed around that constraint, it is more than possible. I'm sure that IHI likes having their name on the turbo.
That was a freakin awesome read!!
I'd love to go to their open house next year!
