EDIT: the stock 06 y-pipe mod shown here will get you running, but the plastic fatigues early. Make up your custom y-pipe based on this geometry....update soon.
I finished installing a TD04 and an 06 WRX intercooler. In order to make the y-pipe work, I did the mods shown in the photo, that is a 2" metal pipe section in the middle.
Cut your elbows long the first time!
Works great, just did the intake manifold gaskets and throttle body gasket as well as replace a bunch of vacuum lines. No more leaks, and 9-10psi.
1991 SS build thread: http://bbs.legacycentral.org/viewtopic.php?t=40430
I cut up a cheesy aftermarket silicone Y-pipe to get the elbows. You could order some generic 2" stuff, a 90* and a 30* would probably do it. Plus the stock 06 pipe, of course - I cut it right on the top of the first bellow section below the junction.
Some 100+psi 1.25" ID hose from the hardware store and a 1" to 1/2" PCV reducer with a short section of 1/2" PVC bent trap line. Not a long-term solution perhaps, but it got the job done until I can find the metal parts I want.
Update - this doesn't last, as the plastic Y-portion fatigues and eventually cracks. This gets you running, but only for a few hundred miles before boost leak.
I will update with my exact fix hopefully later this week.
Yes. I used an all-silicone aftermarket y-pipe in place of the plastic one.
I had to cut it up to get the geometry correct, but the "Y" portion is intact. A couple pieces of 2" exhaust pipe cut to the correct lengths were needed to extend one arm and the portion down to the turbo.
I used an OEM STi 90* elbow for the turbo outlet, I just had to trim the turbo side a little shorter so that the plastic stop on the outside of the elbow cleared the IAC stuff.
I used some Constant Torque clamps from NAPA for this, they are very nice, but $6 each!
No pics right now cause it's all in the car, but next time I take it out I'll photograph it.
I also bought a Prodrive silicone Y (for an FXT or 06 WRX) from Cosworth on eBay for $60, so I have a backup. With this Y, all I would need to do is cut halfway down the angled extension to the turbo, turn that 180* over so that it points down instead of to the side (splicing with a 3" length of 2" exhaust pipe), and then add a length of 2" exhaust pipe down to my STi 90* elbow.
OK, here is a diagram of what I am talking about with the FXT pipe. I have NOT cut mine up yet, as my other silicone Y is working fine, but this solution would be a bit cleaner than my first go-around.
Here is the one I bought (or search the Costworth site for the Prodrive FXT y-pipe): ebay link
ScottyS: That y-pipe diagram no longer works. Do you have any pictures of what you ended up with now?
~9 months later, my cutting job on the 02-05 Samco hose was apparently too short. The y portion of the hose is slipping off the 2" exhaust tubing from the turbo. Just not enough material there anymore for the t-clamp to bite into. Wasn't a problem the past ~8 months, but is suddenly now. Go figure.
Thinking of going with the Samco 06-07 TMIC hose this time
I don't have a pic immediately available, basically I used the middle-"Y" portion of the 06-07 Prodrive hose and had to extend one side and also the turbo leg with 2" pipe. A stock STi 90* or 4-5-ply eBay 90* both work on the turbo side.
It's solid now, I use the NAPA constant-torque clamps. Expensive, but worth it.
Mine used to get slick from oil vapor getting recirculated from the PCV system, but since I put a modified air compressor filter inline, my intake's been dry as a bone.
Pics not for a while, I've been meaning to shoot the mods in the engine bay next time I have things apart. Basically, I put the little glass bowl filters for an air compressor inline with the PCV and the valve breathers right before they go back into the intake. I also drilled a couple of small holes in the filter element to allow full airflow, but still require the air to change direction several times in the process. This seems to be enough to get the oil out, as it has been collecting at the bottom of the glass bowls.
I used the air compressor filters in the tool section of Home Depot, and the approximate-sized NPT fittings for the hose diameter.
