EJ20g DOHC Heads/intake/440s
Hey guys!
I am selling my set of 20g heads/intake manifold complete with rails and all/timing gears/timing belt
looking to get 450 shipped.
Tim
93 Legacy SS Winestone 5mt swapped
Megan Racing Bellmouth 13psi
WRX Intercooler and Hoodscoop
JDM ej20G DOHC head swap, wiseco pistons and td04 in the making.
Sorry to be off topic here but how do you tell which version heads you have? I have a set of JDM DOHC heads but don't know which version they are and I've asked the guy who I got them from twice which ones they are and he never responded. Although he responded to other pm's....
If the cams push directly on big round discs then they are WRX.
If the cams push on small, squarish pad/rockers and those, in turn, push on the valvestems they are Legacy.
So the only way to tell is to take off the valve covers and look at the rocker assembly?
No, there are other clues. I'll try and post pics tonight, after work.kimokalihi wrote:So the only way to tell is to take off the valve covers and look at the rocker assembly?
Another quick one to check...One bolt holding the coil down is WRX. Two bolts holding the coil is Legacy.
The WRX heads.
They have a newer HLA setup that allows you to rev slightly higher without floating a valve and a smaller combustion chamber that raises the compression ratio higher than the older style Legacy heads which gives you better low-end.
And if you want to... you can swap out the valve train from 98 Legacy GT heads and have a completely solid lifter assembly... Or so Dave tells me.
Arctic Assassian
NuclearBacon
curious if this is still available? any pics?? curious why you didnt do the swap yourself? sounds like you basically have all the parts you need minus some smaller pieces.
thanks!
thanks!
-Luigi-
....Yes like nintendo
1987 GL10 Sedan 3.700 LSD
1988 XT6 FT4WD 3.900 Diff Lock
1992 EJ22T Touring Wagon 5MT Swap 4.111
heads/mani/injector
nice package for a good price. just out of my rearch at this time.
bump for a good deal.
be well,bepa
be well,bepa
91 SS/ 01 MB ML 55
Bronx, NY.
Bronx, NY.
94SS_Canada
