bolt up? or no?
bolt up? or no?
my friend has parts from his bug eye wrx wagon left after his full sti conversion. just wondering if they will bolt right on to my 1990 legacy or if ill need to modify something. the parts are front wrx brakes, hubs, axles, and lower control arms with an anti lift kit with poly race bushings in it. thanks for a
1990 L, 5mt, awd
eh, the control arms should work with maybe a small amount of modification but then if you use the hub assembly you will need bigger wheels to fit the wrx brakes.
Here is what I suggest: Drag these parts over to the corresponding corner of your car. Jack your car up and pull the wheel off. Examine both your OEM parts and the parts you want to put on and see if they will fit. Then enlighten me
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
