3 cylinders= better MPG
not sure where this thread belongs. this may some dumb not smart for the car but if i was to unplug one of the boots from a spark plug would i be able to use just 3 cylinders safetly to conserve gas
if you were serious. You would need to take the plug completely out so there will me no compression stroke. The compression would be added resistance which will take some of the power or lack there of from what you will be getting from running on three cylinders.
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
06 ZZR600
Back in the gas shortage of the '70's (does anyone else remember that panic?) there was a kit to convert VW engines from 4 to 2 cylinders that inclued bob weights and cylinder block off plates. Most would get a big bore kit (1800+ cc) and split it with a friend. They'd end up with a 900 cc opposed twin that had a VERY unique exhaust note. Think Early BMW motorcycle...
Not great for racing, but out on the highway they got 30+ mgp (not bad for the timeframe...)
That sounds counterproductive. Not saying you're wrong, but compressing air you're not using for power would just be more pumping losses.
This has been beat to death over on the gassavers.org forum. The verdict: don't do it unless you want less power, rough running, and likely lower mpg. In order to get any hope of improving fuel economy you'd have to deactivate the valves, as well as the injector and sparkplug ala Hemi w/cylinder deactivation. One dead cylinder on a flat-4 would put all kinds of loads on the crankshaft it wasn't designed for. If you want to improve mpg, there's much much better and cheaper ways to do it. I got at least 15% better fuel economy in my car with just the driver mod (adjusting the loose nut behind the wheel).
1991 Legacy LS wagon - owned it twice now, EG33/WRX trans swap in-work
2013 Impreza Premium hatchback, manual - SOLD
1994 Subaru Legacy Mi - SOLD
2005 Legacy GT Limited wagon, manual - SOLD
I had no problem doing 85 on 3 cylinders with a melted exhaust valve. For about 25 miles anyway. I don't recommend melting valves to increase mileage. Especially won't save you money with all the oil you'll eat.
Re: 3 cylinders= better MPG
SILINC3R wrote:not sure where this thread belongs. this may some dumb not smart for the car but if i was to unplug one of the boots from a spark plug would i be able to use just 3 cylinders safetly to conserve gas
Are you fucking serious?
I did that inadvertently back in the '80s... I had a '73 Thing done up Baja style w/ a 2110 dual Webber monster engine. It started running rough one day, low on power, etc. Drove it almost a week before I had time to look at it... found the left bank rocker retainers had broken, the whole rocker arm assembly basically fell off and was lying in the valve cover... 2 cylinder operation. Sorta sucked from a NVH / drivability perspective, but it was interesting to me that it operated as well as it did.tahiti350 wrote:Back in the gas shortage of the '70's (does anyone else remember that panic?) there was a kit to convert VW engines from 4 to 2 cylinders that inclued bob weights and cylinder block off plates. Most would get a big bore kit (1800+ cc) and split it with a friend. They'd end up with a 900 cc opposed twin that had a VERY unique exhaust note. Think Early BMW motorcycle...
Jerry
