Have any of you turbo guys upgraded your fuel pumps? If so, what
brand did you use and what increases did you see? My brother did so
on his GSX and found better gas milage AND more power. Does that
sound familiar?
Jason
Turbos and Fuel pumps?
--- In BC-BFLegacyWorks@egroups.com, "Jason Grahn" <jgrahn555@h...>
> sound familiar?
> Jason
Haven't done it yet, but will sometime this year. I'm going to go
with a Supra Twin Turbo mainly because it will flow more fuel then
most would ever need, is a very straight forward install( so I'm
told), and it's an OEM part which means,the majority of the time,
it's made to be quiet and last thousands and thousands of miles
I'd be interested to hear from others as well who did a swap. Was
there much involved?
-Matt
> sound familiar?
> Jason
-Matt
I recently swapped my factory for another factory fuel pump. It made the car start and run again which was my primary goal but...
The pump I put in had the fuel guage float and rheostat on it along with other bypass stuff and such. Do the off brand replacement also replace this or do they replace only the pump?
-Matt
-Matt
