pp6 wiring diagrams for 91SS
macipusy
Post by macipusy »
Does anybody have the wiring diagrams for the perfect power 6 for a 91 SS?
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
Post by 555BCTurbo »
There aren't any...
I lost the one that I made after doing the PP6 install...but the pin outs available on here don't apply correctly to the turbo models...so I had to go through with a test light and find all of the wires separately.
macipusy
Post by macipusy »
What is the best way to go about the install?
maciek puszynski
16 WRX | 6mt | fa20
Find the wires that it hooks to and solder it in
You better have a wideband before you try any sort of tuning though
macipusy
Post by macipusy »
What is the process of finding the wires it hooks to?
maciek puszynski
16 WRX | 6mt | fa20
macipusy
Post by macipusy »
I got the pp6 unit used and also included was the external 2.5 Bar Map sensor which I also need to figure out how to install.
I probably will not get to the install untill late spring but need to gather all the info by then.
I guess I still need a wideband O2 sensor.
maciek puszynski
16 WRX | 6mt | fa20
douglas vincent
Post by douglas vincent »
94legacy2.2
Post by 94legacy2.2 »
Hey douglas, will this pinout work for a 94 also?
Im making a adapter harness now which plugs between the stock harness and computer to make this PP a plug and play setup. Just wondering if I can follow your link above'
Tyson
im slow---Location:Colorado
Got squirt? http://www.msextra.com/index.php
