quick question about spark plugs
92ss satinsvoice
Post by 92ss satinsvoice »
if you car is running really rich around 10:1 afr's most of the time. with new spark plugs.
how long till the spark plugs give out? from being fouled up
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
Post by 555BCTurbo »
They will probably go for a while...but I'd say get your ridiculous AFRs sorted out
92ss satinsvoice
we put another map in with alot less fuel. now we just have to figure out why its not running.
Andy
94 L n/a 5spd, Rip
Your map is probably not right...
92ss satinsvoice
no, the map is fine. its the map from daves car. it wasn't running before we did different maps. i ran a log while i was cranking the motor over and noticed the fuel injectors pules and DC weren't doing anything, not firing. but the weird thing about it is the Link is its getting triggers. so the crank and cam sensors are working.
wiring issue or link problem?
Andy
94 L n/a 5spd, Rip
keelhaul
Re: quick question about spark plugs
Post by keelhaul »
hello.
can worn spark plugs cause hard starting when the engine is warm? there is something wrong with either my spark plug(s) or my coil(s). having slight misfire when my boost hits 14 psi. im currently in winter-modus, so im more useless than usual :/
1992 wagon ej20g
Perhaps they are not gapped properly.
Yeah, I'd check the gap, and/or check for cracks in the porcelin of the plug.
keelhaul
Post by keelhaul »
thanks for your answers.
i have four NGK plugs, number is BKR6EVX. how big gap would you reccomend on these plugs, before i put them in my 92' EJ20g, with 14 psi peak boost?
1992 wagon ej20g
I would not go any larger than 1.0 to 1.1 mm at the most for a gap.
keelhaul
Post by keelhaul »
cool.
considering the state my air/fuel/oil filter was in, i dont think plugs has been changed for good while either. because that job sucks compared to filter-change on the ej20.
1992 wagon ej20g
