i know these don't pop up very often.. pretty sure they were in the VZ models.
ej20 NA
what's the specs on these guys??? hp, cr, etc
JDM dohc 2.0 non-turbo
1994 SS "JDM-OEM"
1994 gt wagon, next build
1994 turbo wagon
1994 turbo wagon
ok found some stuff
bore & stroke
92.00 mm × 75.00 mm
3.62 in × 2.95 in
CR- 9.70:1
power
150.1 PS (148.0 bhp) (110.4 kW)
@ 6800 rpm
torgue
172.0 Nm (127 ft·lb) (17.5 kgm)
@ 5200 rpm
bore & stroke
92.00 mm × 75.00 mm
3.62 in × 2.95 in
CR- 9.70:1
power
@ 6800 rpm
torgue
@ 5200 rpm
1994 SS "JDM-OEM"
1994 turbo wagon
1994 turbo wagon
