FS: 3.90:1 VLSD
FS: 3.90:1 VLSD
I have a lsd from my 91 turbo I need to sell. Make me a reasonable offer, and we will see if we can deal.
SOLD
SOLD
The rear diff needs to be matched (gear ratio-wise) to the transmission. A working vlsd would provide you with better traction on slippery surfaces. To test if it still works? Rotate the axle. If the other side turns the same direction then the vlsd works (with the limited pressure you are putting on it)yazmo wrote:tomoroow im goi ng in junkyard around here and check if i can find some what do i need to do to remove it! what else need to be take off?
As far as going to a higher final drive (eg. 4.111 or 4.44 with a matching transmission, of course!) you should do a search on it's benefits or detractors. Your engine will be in a different rev range than it was before to maintain the same speed.[/b]
