Oil sensor leaking
Oil sensor leaking
While the picture doesn't show it very well, it appears my oil sensor (thats what it is, right?) is leaking oil out the top. Worthwhile to replace?
'11 WRX Limited
'94 TW | R.I.P.
Ya replace it before it gets worse. My 93 did the same thing, and eventually started making a large puddle on the motor. It is only $10. Honestly you can just get a generic one. Then again yours is not NEARLY as bad as mine.
Or, if its just leaking, you could remove it, reseal it (w/ teflon tape), and re-install it.
