SS Third brake light heads up
Hey guys, my dad was behind me today and noticed my third brake light was not working. Turned out to be a broken wire. Might want to check yours, looks like the wire is subjected to alot of movement when you open and close the trunk. I found one black wire broken, and I just used a wire clamping piece my dad has in his truck and wrapped everything up tight up some electrical tape. You can simply pull out the wire it seems to be a decent length. Just a heads up guys!
