hi guy i just go into the process of installing front speaker on my sedan 1994, its seem that the spacer from the original speaker cannot be use.
right now i am looking for these front speaker so please if anyone know here i can get them its seem that i have to drill hole
bcuz the spacer hole for the screw is bigger than my keenwood speaker.
anyone have clue
thx in advance
looking for spacer for front door speaker leagcy 1994 sedan
You should be able to get plastic spacers at any stereo shop, best buy, etc.
thx for the reply ill try both drill out rivet and check for plastic
btw do you know if those plastic spacer are inclined like the original one.
is there a reason why they make a side deeper than the other except for making the speaker look like straigh with the door?
also i dunno if those spacer will fit the original hole if not what should i do?
drill new hole and put a screw with taro on the other side?
The plastic spacers are not inclined.
They should work. I've 1" spacers in my car since 96 or so.
