Checked Timing. One wire flashes slower???
Slow Hatch
Post by Slow Hatch »
Put the timing light on, and just figured I'd throw it on every wire. Now I just noticed that the rear pass. side wire wasn't flashing as fast as the others. Is this normal, or could possibly causing my hesitation?? Thanks
SLODRIVE
Post by SLODRIVE »
Not normal. Try swapping the wires around and see if the condition re-occurs.
http://www.slodriveracing.com
-And more!
Skruyd
Post by Skruyd »
Slower or inconsistant? The light will only flash when it detects a pulse in the wire. So it's either your coil going out, wire is not connected or going bad, or your plug is bad.
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
