Door chime?
Door chime?
I tried searching, but I didnt really find anything. I want to remove the door chime, because it is very annoying but I would still like my roof light to light up when the door is open.What does the door chime thing look like where is it at?I tried looking under the dash but I wasnt able to pinpoint its location.Thanks in advance.
Are you talking about the Key warning chime???? It look like it's in the Combination meter like Lego said but it runs through the Automatic seat belt control unit. Try unplugging the big plug on the control unit and see if that stops the dinger. If so, the books shows it is terminal 4 on that plug that powers the dinger. If you need the schematic I can always post a pic if you can't find one.
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
06 ZZR600
you can just unplug the switch at the key cylinder. Its a black 2 pos plug if i'm not mistaken. Its located along the rest of the wires coming off of the key switch right where your right knee would bee when you take the dash panel off. It will be very thin wires like 22 awg ish.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
In the trunk on the left hand side "driver side". It should be near the power antenna. Has two plugs in it.uberoo wrote:what does the control unit look like and where is it?
06 ZZR600
06 ZZR600
Why on earth would you unplug the whole control unit when you can do what I said in one post above this one?Skruyd wrote:In the trunk on the left hand side "driver side". It should be near the power antenna. Has two plugs in it.uberoo wrote:what does the control unit look like and where is it?
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
I hated that noise too. I took my gauge cluster out and found out where that noise was coming from. Then I filled the little hole with liquid nails thinking it would kill the noise. It didn't. Made it not so loud but still quite audible. I just left it alone after that though.
I'm not guessing here folks. I unplug the stupid thing when I'm working on the car and need the key on and the door open.uberoo wrote:I will try the ignition switch first then check out the computer if it doesnt take care of the chime..
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
