SAY NO TO DRILLED!!!!!! Bad bad bad.... Vented o.k.
-----Original Message-----
From: dfullerton [mailto:dfullerton@dfullerton.screaming.net]
Sent: Saturday, January 20, 2001 36 AM
To: BC-BFLegacyWorks@egroups.com
Subject: Re: [BC-BFLegacyWorks] Uh! Oh! my front pads are down to the metal with sparks flying
looking for the same thing myself , saw some nice stuff in oz vented and drilled for $136 each thats about£50 not bad and cheaper than uk standard.
----- Original Message -----
To: Legacy egroup <mailto:BC-BFLegacyWorks@egroups.com>
Sent: Saturday, January 20, 2001 3:13 AM
Subject: [BC-BFLegacyWorks] Uh! Oh! my front pads are down to the metal with sparks flying
Hi there
Anyone with UK cars recommend a good make/place I can get some front discs and pads or shall I just buy the standard ones from the dealer ?
cheers Guys
Penty
eGroups Sponsor
<http://rd.yahoo.com/M=168002.1291681.28 ... token=7406> Get 3 CDs for ONLY $9.99!
<http://us.adserver.yahoo.com/l?M=168002 ... =903326800>
Uh! Oh! my front pads are down to the meta l with sparks fly
I'll second this. Cross-Drilling just removes material from rotor, which in turns gives it the ability to dissapate heat. Cross-drilled help in two ways vent brake gasses and cooling. For street use, you will most likely not benefit that much from the added cooling. For race purposes, I'd say you would, but you'll kill your rotors alot sooner. Slotted are good, because they remove little material, yet vent brake gasses. I had a set of cross-drilled brembro's on my 90 Legacy, and like any other rotor that has been on that car, I warped them. I did a no-no and turned them...and they warped like in a month or two. I've got stock rotors on the front now, and still have the cross-drilled in the rear...they feel like they are startin to warp...so they'll probably be going soon too. In reality the rotors on my legacy are too small, and is why I've warped a good 3 sets already
But at the time I don't have the money to upgrade to larger rotor and caliper...plus then I couldn't use my snow tires.
If you can find just slotted rotors....go for them....if not...just get normal rotors.
Sent: Mon 1/22/2001 12:31 PM
To: 'BC-BFLegacyWorks@egroups.com'
Cc:
Subject: RE: [BC-BFLegacyWorks] Uh! Oh! my front pads are down to the meta l with sparks flying
Hi there
cheers Guys
Penty
eGroups Sponsor
Cc:
Hi there
cheers Guys
Penty
eGroups Sponsor
There is a very informative article on brakes and upgrades in this months
issue of Grassroots Motorsports. It is very scientific and gives pros and
cons to certain modifications.....check it out!
KMH
To: <BC-BFLegacyWorks@egroups.com>
Sent: Monday, January 22, 2001 2:39 PM
with sparks flying
But at the time I
> normal rotors.
> Josh
> From: Barrett, Sam
> Cc:
> From: dfullerton
> From: penty <mailto:penty@nettaxi.com>
> To: Legacy egroup
> Hi there
> cheers Guys
> Penty
> to:
> <mailto:BC-BFLegacyWorks-unsubscribe@egroups.com>
> eGroups Sponsor
> <http://rd.yahoo.com/M=168002.1291681.28 ... =170006498
> 3:N/A=564919/*http://www.columbiahouse.com/gateway?token=7406>
> <http://us.adserver.yahoo.com/l?M=168002 ... groupmail/
> S=1700064983:N/A=564919/rand=903326800>
KMH
with sparks flying
> normal rotors.
> Josh
> From: Barrett, Sam
> Cc:
> From: dfullerton
> To: Legacy egroup
> Hi there
> cheers Guys
> Penty
> to:
> eGroups Sponsor
