Replace head bolts?
Replace head bolts?
The downloaded factory service manual I'm using doesn't say anything about replacing the head bolts (I'm replacing head gaskets on '97 ej25d) but when I was comparing part prices online, Napa's site says that replacing the bolts it recommended. I'm sure some of you guys have gone both routes, what's your recommedation?
Todd
2002 Legacy GT Wagon 2.5/5mt
1999 Legacy Outback Limited Wagon 2.5/4eat(wife)
1998 Forester S 2.5/4eat
1972 Buick Electra Limited 455/TH400
1988 Jeep Grand Wagoneer 360/TF727
you should always replace head bolts when you remove the heads / a head. Head bolts are designed to stretch when you tighten them down. They do this to make sure that you get a perfect seal. They retain this shape after this. So you need new ones so you can make sure you have a good seal. Now that said, it is not uncommon that people reuse them and a large percentage of those people have no problems because sometime they have a little bit more they can stretch. Now THAT said ... do you want to take the chance?
99 Toyota Celica GT
91 Celica GT-Four All Trac
89 Toyota MR2 Supercharged
2010 Toyota Tacoma SR5 Quad cab
2010 Acura RDX turbo
Not necessarily true , not at all. Some vehicles' head bolts are indeed "torque-to-yield" and must be replaced every time...but many, many vehicles (including EJ22s and ALL old-school V8s) use high-strength fasteners that do not appreciably stretch at all, and can be reused without any problems whatsoever, provided of course the threads are still good, hasn't corroded, etc.Xander_X wrote:you should always replace head bolts when you remove the heads / a head. Head bolts are designed to stretch when you tighten them down. They do this to make sure that you get a perfect seal. They retain this shape after this. So you need new ones so you can make sure you have a good seal. Now that said, it is not uncommon that people reuse them and a large percentage of those people have no problems because sometime they have a little bit more they can stretch. Now THAT said ... do you want to take the chance?
http://www.slodriveracing.com
-And more!
-And more!
If Doug hasn't had a problem with the frequency he pulls heads, then anyone should be fine.
I too was wondering this and at the price of new OEM headbolts or ARP I would certainly take that risk by reusing them vs paying out the ass for new ones every time.
Yeah I reused my head bolts as well. Talking with CCR engines, they reuse head bolts as well. However, do have a slightly different torquing procedure.
You mean something different than the rediculous voodoo torque dance we all follow from the FSM?However, do have a slightly different torquing procedure.
Yes. I don't recall what it is though.gijonas wrote:You mean something different than the rediculous voodoo torque dance we all follow from the FSM?However, do have a slightly different torquing procedure.
