Bad starter? edit: nope
brand
Post by brand »
Went out to move my 91 into the garage and it won't start. It has been sitting for about 5 days. I hear the solenoid in the starter click but it won't turn. I looked at the grounds and they look okay (though I will check again tomorrow when it's light out) and I tapped the starter with a hammer to no avail. Is it time for a new starter or is there something else I should check? Have had no problems with the car since I got it in March, it's always cranked over immediately.
Also, just for grins, I started pulling plug wires, and the wire in cylinder #1 has what appears to be a small amount of oil around it. I figure now my best bet is to replace the plugs and wires (I have spares on the shelf) but I'm wondering if there is anything else I should do to prevent this from happening.
Thanks!
91 SS with a bunch of parts waiting on the shelf
94 SS with things and such
08 STI with stuff and junk
What was the battery voltage? If you can put a charger on it, and it starts, you may have just had a weak battery.
The solenoid on the starter is usually what goes out. You can replace the contacts very inexpensively, and have a good starter.
brand
Post by brand »
Legacy777 wrote:What was the battery voltage? If you can put a charger on it, and it starts, you may have just had a weak battery.
You win the prize. Just hooked up the charger and it started right away. Not sure why I didn't try that before posting. Thanks!
SPUMONI_RT
Post by SPUMONI_RT »
Where could I find more info on replacing the contacts?
-SRT-
-Spumoni-
