stutter from 2000rpm -3000rpm
Dirty91Legacy
Post by Dirty91Legacy »
ok so for some reason my car will smoothly accelerate throuth the rpm range on all gears at like 25% throttle now in any gear as soon as i go more that that between 2000rpms and 3000rpms it stutters or misses and i have no idea why.....now the things ive done to try and troble shoot the problem. new plugs correctly gapped so i know thats not the prob. injectors cleaned, new fuel filter......also one other thing i have a CEL for the canister purge solinoid valve im wondering if its stuck open causing a vaccum leak maybe?!?!?! idk if i rip the system out and plug it up will that help....??? i need input lol please somone HELP me
When in doubt...Go flat out.
-Colin Mcrae-
have you checked your fuel pump? it could have issues. Maybe also plug wires? I had a similar problem and found out my pump was shot. When igot on full throttle it's hesitate and i'd hear some popping, but when i eased into throttle it'd be fine. i guess my problem was the pump would slowly produce fuel but when it needed it on demand it'd cut out then fire up again... then the pump just died on me.
Dirty91Legacy
Yea I'll have to check that out
-Colin Mcrae-
Legacy Konig
Post by Legacy Konig »
I remember some time ago having this exact problem, exact.
After much investigation, it ended up being a faulty spark plug wire.
Just one of the wires was inconsistently shooting electricity down the side of the terminal rather then going through it.
I'd recommend removing all your plugs and wires, and then inspecting your spark plugs. Check your plugs out, scrutinize detail. The shape and details on your spark plugs will show you what's happening in your engine while it runs.
Replace the plugs and wires-
This would be a good step.
1994 Legacy L
1990 Legacy LS "decommissioned"
cj91legss wrote:have you checked your fuel pump? it could have issues. Maybe also plug wires? I had a similar problem and found out my pump was shot. When igot on full throttle it's hesitate and i'd hear some popping, but when i eased into throttle it'd be fine. i guess my problem was the pump would slowly produce fuel but when it needed it on demand it'd cut out then fire up again... then the pump just died on me.
eek I need a new pump lol.
oh no way, was that really the problem???
NICO
Post by NICO »
coilpack
yeah that could be it too
Dirty91Legacy
i forgot to mention when i bought the car the number 2 cylinder plug had a heli coil repair done to it could this cause a problem?
-Colin Mcrae-
