Ultimate Sleeper Legacy
SubiePrice88
Those tires don't have long to live.
This is little more "out there":
http://www.youtube.com/watch?v=-iYp79RS2X0&feature=fvw
Mattheww044
I'd argue that the only interesting parts of a first generation Legacy are the flat engine (gone) and AWD (also gone).
If you insist on a swapped RWD Subaru the first choice should be a 95 impreza Coupe since its quite a bit lighter than the Legacy.
I said Miata because it has a serious weight advantage. I said RX-7 because it has a sexy exterior.
It's all about traction. There are other ways of getting traction with rwd. They might be a little more complicated, but it's unbeatable for the cool factor and nothing I'd expect the typical car person to attempt with all the impractical things they often do.
http://www.photoessayist.com/canam/chap ... parral.htm
Hmm, that was an interesting read. Thanks Steve.evolutionmovement wrote:It's all about traction. There are other ways of getting traction with rwd. They might be a little more complicated, but it's unbeatable for the cool factor and nothing I'd expect the typical car person to attempt with all the impractical things they often do.
Mattheww044
What about a turbo 13B swapped rwd Impreza coupe? Would that be interesting?ciper wrote:I'd argue that the only interesting parts of a first generation Legacy are the flat engine (gone) and AWD (also gone).
[quote="RJ93SS"]u fail, epicly[/quote][quote="evolutionmovement"]Don't do drugs, kids, men may not need nipples, but we look a lot funnier without them.[/quote]
