SRS light is on after steering wheel removal
macipusy
Post by macipusy »
So a week ago I adjusted the location of the steering wheel on my father-in-laws 95 Legacy L.
I unhooked the battery, unbolted the airbag, unplugged the two connectors, took the steering wheel off, adjusted location and put it back together in the correct order. All plugs were plugged in.
As soon as we started the car the SRS light was on. The horn works, so it's not a grounding issue.
I was very careful with the air bad unit when it was off the car.
Any ideas why this would happen?
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
BSOD2600
Post by BSOD2600 »
If any one of the yellow airbag connectors isn't double latched, it'll trigger the light. I found this out the hardway after removing the dash for heatercore replacement. Turns out, the yellow plug near the fuse box was connected, but not both latches.
'11 WRX Limited
'94 TW | R.I.P.
Yes exact same issue with my car when I was doing some fuse box inspecting.
macipusy
Post by macipusy »
I will take it apart again and double check the connectors.....is there anything else it could be?
maciek puszynski
16 WRX | 6mt | fa20
