Seems like when I check my fuel trims. Lets say 1-7. Sometimes it is consistently increasing so -5.5, -5, -4, etc etc. Yet sometimes they are all over the place like -5.5, 5, -1, 14. How does that happen? Tried replacing the o2 sensor same sort of symtoms but I didn't reset the ECU this time I did and it seemed to be fine after driving around went back to like -3, -2.8 , -1 etc etc.
What would result in this? Exhaust leaks? Could a bad fuel pump not given consistent pressure create a problem?
Fuel economy is definitely not nearly as good as it was when I bought the car which really sucks
Octane factor now stays at 100% all the time.
