Subaru Select Monitor and RevScan Questions
New to SSM cable and RevScan. Ive searched on here and RevTronix website and couldnt find what Im looking for, maybe someone could point me in the right direction.
I Just got the SSM cable from EvoScan and I have the RevScan on my laptop.
Ive used scan tools before, but that was 4 years ago in a Automotive Tech school and they were OB2, so Im a little rusty. But never OBD1 with a laptop
What do you plug the cable into? Obviously the USB goes to the comp but what about the other ends?
Also do I plug it in and than start the car? Or Have the car running and than plug it in?
Any and All info would be nice
-Thanks
-Thanks
-Jordan
"Nothing Stings Like a Subee"
1993 Legacy Wagon, 5MT, 220k!
Re: Subaru Select Monitor and RevScan Questions
SSM Cable:
Is this it, the yellow one:
Looks like it, but which way does it go in? Because it looks like it could go in either way
-Jordan
1) ODB-1 is a whole other ball game
. Full of non-standard locations for each car for parameters. I assume you've found the EvoScan thread here and my updated config file by now? RevScan works out of the box with no config, except it doesn't expose all possible parameters and you don't know what it's really doing (I have a hunch it's using internal lookup tables for some parameters, which then isn't the real ECU data).
2) Yes, plug into the yellow cable on the car. Unless your connector is messed up, it clearly only goes in one direction.
3) You can connect/monitor the ECU if the engine is off but key turned to ACC. Most parameters will be 0, but others will still work (throttle, engine temp, MAP sensor, etc).
'11 WRX Limited
'94 TW | R.I.P.
Thank you BSOD2600!! I honestly knew you had the answers haha I was just waiting
I have not found the EvoScan thread yet nor the updated file config. Im currently downloading the EvoScan (much bigger than the RevScan file)
Im pretty excited now!
-Jordan
Just moved into my house and finally got internet back, w00t.
evoscan thread. My updates are near the end.
'11 WRX Limited
'94 TW | R.I.P.
woot woot!
Thanks man, Ill read the thread.
So EvoScan isnt set up for our cars?
-Jordan
Not out of the box. It's configurable though to work...SubiePrice88 wrote:So EvoScan isnt set up for our cars?
I've been in contact with the EvoScan author and he stated the next release was:
1) going to implement my/logcall1 Subaru config files
2) going to have the ability to read in multiple config files. That way not everything will be stored in Data.xml. much easier for sharing configs online for different cars!
'11 WRX Limited
'94 TW | R.I.P.
I NEED A LAPTOP!!!!!!!!
Mattheww044 wrote:I NEED A LAPTOP!!!!!!!!
Why? haha Ive got one and I wont charge much
When will the next release be?BSOD2600 wrote:Not out of the box. It's configurable though to work...SubiePrice88 wrote:So EvoScan isnt set up for our cars?
I'll keep reading the EvoScan thread some of it goes right over my head (obd2 is soooo much easier haha).
How do I use your files? or get them onto my EvoScan?
-Jordan
How do you get the cable to work?
For some reason my computer will reconize the new device and a windows help wizard pops up and asks if I want to install the device and than I go threw that process but It says it cant find a way to run it.
And if I plug the cable into the car and my comp it comes up with "cant find vehicle" on RevScan
EDIT: Uh found this..... "HighSpeed USB Cable for Subaru 1990-1998 SSMI vehicles. Perfect for EvoScan. Specifically supports pre 1998 Subaru vehicles with a 9 pin diagnostic port for EFI Datalogging, or if your vehicle has a 16pin obd2 style plug with metal pins in pin12 and pin13, you will need this SSMI cable. Included is virtual comport software to use this USB cable with serial port based software."
Yeah didnt download that. Is that my problem?
-Jordan
Official? No idea, he's slow with those. Although, tends to release a new beta every month or two on the evo forum he frequents... link to the thread he updates... although it seems his website was hacked and evo account banned or something. You can create a support ticket to request 2.7 beta 5.SubiePrice88 wrote:When will the next release be?
Yup, need the driver. It'll show up as another COM device in Device Manager. Since the Revtronix site is down (and had the drivers on there)...if you purchased EvoScan they were placed at \Program Files\EvoScan\EvoScan v2.6\USB Drivers\ Otherwise you can download them from my site.SubiePrice88 wrote:Yeah didnt download that. Is that my problem?
'11 WRX Limited
'94 TW | R.I.P.
Ok sweet! I feel better now, I honestly cant thank you enough for all the help
Is this the same thing?
EvoScan/EcuFlash/OpenPort 1.3U Requires installation of USB FTDI drivers (installed with ecuflash, or EvoScan will auto install them if no drivers found on logging)
Otherwise you'll get this message: FTD2XX.DLL missing
you can manually install the Evoscan USB drivers: from C:\program files\evoscan\EvoScan v2.6\USB Drivers\x86\DPinst.exe /i
ELM327 USB Cable Drivers and Software: Download Here
-Jordan
I downloaded the one off your site and my computer cant open it.BSOD2600 wrote:Official? No idea, he's slow with those. Although, tends to release a new beta every month or two on the evo forum he frequents... link to the thread he updates... although it seems his website was hacked and evo account banned or something. You can create a support ticket to request 2.7 beta 5.SubiePrice88 wrote:When will the next release be?
Also went threw device manager and I believe i found the file but it says something about how this program is not accepted and asks if I want to continue.
It cant be this hard
-Jordan
You need WinRar to open a *.rar file.
Yes, you need to install the USB FTDI drivers. Make sure you're doing this all under an admin account. What OS you on? What was the exact error message you got when trying to install the driver?
It's only hard for some
'11 WRX Limited
'94 TW | R.I.P.
My OS: XP
Went thru My Computer to EvoScan v2.6 - USB Drivers - x86 - DPInst - that comes up with OpenPort Device Installer clicked next and than comes up with this and askes if I accept or not
"Copyright © 2004-2008 Tactrix Inc.
This hardware and driver are provided 'as-is', without any express or implied warranty. This device reads and modifies code and data for engine computers (ECUs). Improper use of this device or errors within the device itself can cause engine damage and/or render the vehicle's engine computer non-operational. Many ECUs can only be reflashed a limited number of times before the flash memory is no longer functional. Additionally, modification of your ECU's software will most likely void your drivetrain warranty from the manufacturer and violate emission control regulations in some regions. In no event will the device manufacturer be held liable for any damages arising from the use of this software.
This device allows you read code/data from ECUs which can potentially be subject to various copyright and intellectual property laws where you live. It is your responsibility to use (or not use) this device in adherence with these laws.
Permission is granted to anyone to use this device for any purpose, including commercial applications, subject to the following restrictions:
1. The origin of this device must not be misrepresented; you must not claim that you built the device or software. If you use this device in a product, an acknowledgment in the product documentation would be appreciated.
2. Altered versions must be plainly marked as such, and must not be misrepresented as being the original device.
3. This notice may not be removed or altered from any distribution."
Click accept..
Than a screen pops up and says-
"The Software you are installing has not passed Windows Logo testing to verify its compatibility with Windows XP. Continuing your installation of this software may impair or destabilize the correct operation of your system either imediatly or in the future. Microsoft highly recomends that you stop this instalation now and contact the software vendor for software that has passed Windows Logo testing"
Asks if I want to continue or stop the download
Click accept..
-Jordan
OK downloaded this: http://download.cnet.com/windows/3055-2 ... =pdl-redir
and my comp actually reads the file now.
This is all a little harder than I thought, I thought you download RevScan and plug the cable in and its good to go. haha nope!
I'll try it out tomorrow, its late and cold out now
-Jordan
Plugged the cable in today..comes up with Wizard Help and it still doesnt recognize the cable...
-Jordan
You need to click yes/continue the install.SubiePrice88 wrote:Than a screen pops up and says-
WinRar is available from: http://www.rarsoft.com/ -- I would suggest only installing software from the real/main site.
With the RevScan cable plugged into the laptop, open up Device Manager. Do you have any unknown devices (yellow question mark)? If so, then the usb drivers for the cable are still not installed correctly. Open the yellow device, click reinstall driver, and the instead of automatic searching specify the path of C:\Program Files\EvoScan\EvoScan v2.6\USB Drivers\x86\. Then once thats all done, if you unplug and plug the evoscan cable into the PC, it should show up in the Ports section.
'11 WRX Limited
'94 TW | R.I.P.
I think I may have made it a little more complicated than it is, but Matt and I couldnt figure it out.
Im pretty excited though! Thanks!
-Jordan
