Alright guys so some of you already know i went ahead and swaped a 97 ej20g motor in my 91 legacy ss. I went ahead and used the full harness of out of the ss and merged it in the ej20g motor. This was fairly simple since most of everything clipped right in without changing pigtails. It runs really great and im very happy with the swap. However, on start up the car takes forever to start usually about 8 seconds and when its really cold its about 15 seconds of holding the key on the start position (yeah i know its bad for the starter). Anyways so once it starts its usually fine but when it warms up to full operating temperature it misfires on idle? I will be stopped at a red light and it will misfire consistently. I usually hold my foot down on the brake and hold it to 1k and it stops misfiring.I am now wondering if this could be a ecu problem? My question for everyone is how would i fix the long start up and idle misfires? Here is what i already have done to try to solve the problem..
Leakdown was 0% on 1,2,4 cyl and %1 on the 3rd cyl
Compression test was 140,140,138,140
-Cleaned IAC
-New coolant temperature sensor
-New plugs (ngk)
-New coilpack
-New cam angle sensor
-Injectors are in the process of being professionally cleaned and balanced (stock ss injectors)
-New fp
-Used but in good condition tb with tps sensor from a 92 na legacy
EJ20G swapped but having starting/misfiring problems
2005 STi (500WHP with "SlowSTi" as the license plate lol (Weekend Warrior)
1991 Legacy ss JDM EJ20G swap with STi goodies (DD)
Re: EJ20G swapped but having starting/misfiring problems
You mentioned most stuf "clipped" right in. Are you sure all the pins in the wiring were the same?
Legacy777 wrote:You mentioned most stuf "clipped" right in. Are you sure all the pins in the wiring were the same?
Well the only thing that didnt clip in was the cam angle sensor so i ended up getting a pigtail and soldered it in.
A couple of things that won't hurt to check out:
-Make sure there's no vacuum leaks. Triple-check all hose connections and check the intake manifold/TB gasket areas while idling.
-Clean your MAF with the proper stuff.
http://www.slodriveracing.com
-And more!
-And more!
SLODRIVE wrote:A couple of things that won't hurt to check out:
Cleaning my maf wouldnt be such a bad idea.. Ill go ahead and try it and let you guys know how it worked out..
