OBD2 swap in our cars
sleepinsuby
Post by sleepinsuby »
wondering if anyone has swapped out our obd1 for an obd2 full swap? Iv been thinking about trying this for my ej22t/2.5i build just to have more tuning options.
94SS full cage 2.2 hybrid build with 04 2.5i heads,JIC coilovers,jdm 4pots,vlsd,jdm TD05 16g ,top mount IC,950 injectors,running ms3x em
91ss ej22t 110k,rebuilt heads,new seals,delta220 cams,td04,wrx top mount,wrx flywheel,wrx trans
92L drift project h6 rwd
Re: OBD2 swap in our cars
You need a full wiring harness from the car you want, and then merge it with the old harness. It is not for the faint of heart.
