I picked, a parts car 1992 wagon NA Automatic about a year ago. I never thought
about selling the transmission. Needing money i told her $150 you have somebody pull
it or $200 i pull for you. She decided to pay the 200. So i removed it and had her pick it up.
I was very carful removing it and was positive it worked fine. Had clean fluids in trans and center diff.
180k and drove to the mechanics where the previous owners had the engine pulled.
Soon later i get a call. She said her mechanic put it in took a test drive and it completly
locked up on him WTF. I called him today and asked exactly what actully happened.
Turns out this is the third time hes installed a different transmission and it failed, and he never
wants to touch the car again. Apartly he took it out for a first test drive and it shifted perfectly.
The lady then asked would it make it to Cle Elum from Cashmere. He wanted to prove to
her it was fine so he wanted to drive it another 20 miles. Got in about 15 and smoke started
pouring out the back and making noise and he kept going and it then instatly locked up and
skidded to a stop
What could cause that to happen? It obivously was leaking fluids pretty bad.
He said it sounded like it was maybe coming from the front diff, but could have been the rear
too. Isn't there some sort of shift control module or something in the dash? I have only
worked on 5 spds so i have no idea. Just doesn't seen like its the transmission causing the problems
,because its happened 3 times.
Any Ideas?
