Driver side rear cam seal
vica153
Post by vica153 »
93 Legacy SS, EJ22T
Whats the deal with the driver side rear cam seal? Mine is just a rubber plug, nothing seems to be holding it in. There are holes above and below and it looks like the NA engines have a plate that bolts on and holds the seal.
Are the turbo engines really not supposed to have a plate back there? The holes are there for it, why not just buy the part and put it on?
I think mine is leaking and it seems silly to put a new seal in there and expect hopes and dreams to keep it tight rather than the plate.
SiCkSTi04
Re: Driver side rear cam seal
Post by SiCkSTi04 »
Do you get any play from the plug in the back? If so it needs to be replaced. My NA was leaking after my rebuild, it had play in it so i went to a local junkyard and saw that they normally don't move at all! its pretty dang tight. bought a plug and the plate you stoke of too. no leaks anymore :)
I'm sure by just replacing the one plug it shouldn't leak any more tho. good luck!!
couple threads i found ;)
http://bbs.legacycentral.org/viewtopic.php?f=5&t=40519
http://bbs.legacycentral.org/viewtopic.php?f=5&t=38283
http://bbs.legacycentral.org/viewtopic.php?f=5&t=38441
vica153
Post by vica153 »
Thanks posting the other threads, the search engine on here hates me.
Yeah I think I'll get the plate while I'm at it (Only another $15), I cant see any reason why they would leave it off the turbo.
