Lucas trans fix or conditioner
burgandy outback
Post by burgandy outback »
http://www.lucasoil.com/products/displa ... sion%20Fix
http://www.lucasoil.com/products/displa ... onditioner
looking at this stuff to see about extending trans fluid life (yes I am changing fluid and adding an aftermarket cooler) and or fixing leaks and slipping but I am worried about having it make the clutch packs for driving the rear shaft (name escapes me atm) can't seem to get what you guys call trans x here
Re: Lucas trans fix or conditioner
Are you having any current issues?
The rear clutch packs are made out of the same material that the other forward clutches are made out of....so it should be fine I would think.
