there's 3 wires on the map sensor plug, red, white, and black. i need to know which is which need +v signal and ground
also need to know which wire is +12v on the maf
i am searching but im also gettin really pressed for time at the moment.
need help w/ map sensor plug ASAP!!!!
Re: need help w/ map sensor plug ASAP!!!!
Section 2-7c, page 97 of the 1992_legacy.pdf FSM that's posted...
'11 WRX Limited
'94 TW | R.I.P.
Ok so based off what i read,
white is positive/+5v
red is negative/ground
black is signal
and the red wire of the maf sensor is positive/+12v
it's so an FCD can be installed under the hood instead of at the ecu
black is signal
Which is basically the instructions on http://fcd.chrispaiano.com/cj91legss wrote:it's so an FCD can be installed under the hood instead of at the ecu
'11 WRX Limited
'94 TW | R.I.P.
I completely forgot about this website.
this is for matthew044
