Finaly got off my @$$=put in the EDM lights FRONT AND REARS
dscoobydoo
Post by dscoobydoo »
The harness had been in the car for months and the lights were just sitting in the box.
So I decided to quit being lazy and put them in.
The passenger one moves just like it should, but the driver side one is a bit wonky. I may have to take it apart again and reset everything.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
Re: Finaly got off my @$$ and put in the EDM lights w levele
Is there any wiring involved or is the factory wiring all there already? I want some....
dscoobydoo
You have to create a harness for the levelers to work.
6 wires from the pass light to the drivers light to the dash.
Need to splice into illumination/illumination ground/ power/ power ground
Also the plugs are from an 04 STI light leveler- they did not come with the lights.
05 GD-STI
00- GF
FYI, here's the wiring diagram for the EDM lights w levers. I had make one when I got mine since I didn't have the factory manual.
http://www.main.experiencetherave.com/s ... agrams.pdf
dscoobydoo
PART 2: Now have the rear lights with center fog lights ( aka Audi)
Lights on Image
Brakes on Image
Brakes and lights Image
Rear fogs on Image
05 GD-STI
00- GF
reddragons
Re: Finaly got off my @$$=put in the EDM lights FRONT AND RE
Post by reddragons »
that's cool. looks good really good. what do the front light levelers do?
hmmmmm........ 94 turbo legacy maroon.
1995 impreza L sedan-r.i.p.
1997 cav z24 (seized the motor)
vroom vroom party starter!
kleinkid
Post by kleinkid »
You should get back off your ass again, and come up here and install my leveler switch!
sqc151
Post by sqc151 »
we need to add a drooling smiley so i dont have to lick the screen... :smt016 love the rear lights... 8)
me want a set for my 91 SS.
Yeah the 90-91 tail lights look like ass. I'm trying to come up with a cool solution for them. Only thing I've come up with is removing the chrome trim and playing around with some tint.
What are the 92-94 rear tail lights supposed to look like?
I'd be cautious of running the "rear fogs" like that as they could be mistaken as brake lights. The german cars like Audi that have a rear fog, only have it on one side, typically the driver's side I believe.
sqc151
Post by sqc151 »
new german cars now have them on both sides.
Really.....crazy Germans.
Wow, those look great! I'm jealous. Didja get some good high-output bulbs and make a heavy-duty wiring harness for them? If not, you'll be re-amazed all over again when you do.
European specs allow for rear fog lights either on both sides or just on the driver's side.
The idea behind having two of them is that then you can kind of gauge how far away a car is. The idea behind having one is, like Josh says, to make them look different from brake lights.
If you're in thick enough fog that you have rear fog lights on, I don't think distance information is that useful since you have to be really close to a car to see the light anyway. If it were my car, I'd leave the passenger-side rear fog light bulb out.
dscoobydoo
The front levelers move the headlights up/down about 3 degrees each mark.
John- it's not that hard- as long as you have a harness= do you?
The bulbs are the factory ones- not super bright.
I thought about running just one side- but I can now use the light for when people tailgate.
05 GD-STI
00- GF
kleinkid
Post by kleinkid »
What did the harness you used come off of? No, I don't have one.
dscoobydoo
The harness I have is using a few leveler plugs from 04-05 STI's and a wire loom perfect for the harness: 6 small 18 ga wires inside a heat/oil proof wrap. I have asked my electrician if he would be willing to make a few. He said- maybe. but he would need the STI plug ends, the switch and the cost would be between $80-95. But the result is very neat and tidy and easy to put into the car.
05 GD-STI
00- GF
kleinkid
Post by kleinkid »
The leveler plugs from the '04-'05 STi plug into the leveler at the back of the STi headlight? Need The harness side at the headlight I presume.
This would plug into the leveler connector on the EDM headlights?
And, give the electrician the EDM leveler switch I have.
All sounds good to me. I'll start looking for the STi parts.
Mattheww044
Post by Mattheww044 »
Kimo, i agree on the ass ends of the 91, I painted almost everything black on mine, and i think it makes it look ALOT better....should look even better when I do the black handles and chrome removal.... I think that double sided tape will come off after a few car washes :D
dscoobydoo
This is what my harness looks like out of the car. You can see the front plugs from the STI, and the switch ( mine did not have plug ends) Image
05 GD-STI
00- GF
fancy!
