Help with changing tophats pls!
Shaggy
Post by Shaggy »
I need to get my top hat off to put on my new strut but I can't get the damper nut off, the shaft just spins with it. The strut is out nd I'm going to have to do this to the new ones I have also. Any help would be muchly appreciated
90 2.2 N/A legacy awd wagon with outback struts.
Re: Help with changing tophats pls!
An impact wrench will help in removing that nut. If you don't have an impact wrench, you can try putting a strap wrench around the shaft to keep it from spinning. Sometimes the top of the shaft will have a key for an allen wrench or notch so you can try and keep the shaft from spinning.
If the struts are off the car, be sure to use a spring compressor when removing the top mount.
07Evolved
Post by 07Evolved »
Get one of these...
http://www.harborfreight.com/locking-ch ... 36813.html
It was definitely worth the $9 and can be used for many, many things.
Brad
1991 Subaru Legacy L AWD Wagon 5MT (DD)
2000 Outback 5MT (DD)
2005 AW STi
2010 LGT (hers)
1998 Outback (her DD)
Build Thread
Florin1
Post by Florin1 »
since they're garbage, just put vice grips on them. Worked for me, and yes make sure you use spring compressor.
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
speedmaxx
Post by speedmaxx »
an air gun makes the job much much easier...
93 legacy l
to much to list....
Yeah....if you don't plan to use the strut again....then you can use a chain wrench of vice grips. But if you plan to use the strut again, make sure not to damage the piston rod.
Apex3
Post by Apex3 »
Legacy777 wrote:An impact wrench will help in removing that nut. If you don't have an impact wrench, you can try putting a strap wrench around the shaft to keep it from spinning. Sometimes the top of the shaft will have a key for an allen wrench or notch so you can try and keep the shaft from spinning.
In case he missed it the first time around
You can do it without compressing them(I did, might have been on the STi strut come to think of it), but if you don't know it's under pressure it'll be a surprise when the nut comes loose, and it can be dangerous either way
