Highish compression EJ22T?
Grayguy
Post by Grayguy »
Has anyone built a 22t with like 9-9.5:1 compression? I'm trying to decide how to build the motor for my 97' LGT project...
92' SS: SOLD
Re: Highish compression EJ22T?
The higher the CR you go, the lower boost you'll be able to run. There's trade offs for each option. Maybe someone that has gone down that route can provide some further comments.
Dirty91Legacy
Post by Dirty91Legacy »
build your engine up good high compression+ high boost = Hold on to your butts!!
When in doubt...Go flat out.
-Colin Mcrae-
tturnpaw
Post by tturnpaw »
high boost + anything over 9:1 compression = race gas. under 20lbs + 9:1 compression is fine and better if meth is introduced.
